Temperature UV LED
Nino Nobile
(@nino-nobile)
Temperature UV LED
Hello everyone. Is there any way to know the temperature of the uv led, my printer has been shutting down after finishing an impression, is that normal?
I've been thinking that it could be due to an excess temperature of the UV LEDs, how do I know if the fan is cooling them correctly?
Thank you!
Opublikowany : 22/10/2019 3:59 pm
Teila
(@teila)
RE: Temperature UV LED
Shutting down after a print has finished? There is a setting for that. It can be disabled. You can check the current status of the hardware in the support>status menu before or after a print.
Opublikowany : 23/10/2019 2:11 am
