Slow vs. Fast tilt Settings
I am looking for more information about the differences between the fast and slow tilt speed options for the Prusa SL1 Speed. From the Print Profile section of Prusa's website, it says:
Faster - The default profile for the SL1 and SL1S SPEED and would work for most projects.
Slower - Slows down tilt speed and introduces a pause before each exposure/layer.
Is there any more information about the pause before each exposure/layer? Is there a way to change the pause time based on the slow and fast setting you implement, or are there other ways to test and change the pause and tilt time?
Opublikowany : 18/01/2024 6:31 pm
RE: Slow vs. Fast tilt Settings
I think this is used when you have a very viscous resin and the build plate needs more time to fill resin back in between peels
Opublikowany : 26/01/2024 2:24 am
