SL1S Large chunks of print missing in the middle of a print
Large chunks are missing out of my prints. The chunks are missing in roughly the same spot regardless of the file. I've replaced the FEP film, I'm using files that I've printed many times before successfully. I read the manual and it said the next step would be a faulty print display or UV LED panel. I ran the test and it displayed the company logo correctly but in the prints its obvious that it starts out alright and then fails in roughly the same print every time, even on different files. Could part of the LED panel be failing after a certain amount of print time? Just wanted to see if anyone else had this issue before replacing everything.
Veröffentlicht : 01/07/2022 6:54 pm
