SL1 FW update failes due to invalid certificate
Pagina 1 / 2
Rene
 Rene
(@rene)
Utenti
I bought a second hand SL1 which still runs on 1.3.0
I already exchanged the empty CR1220 battery.
Tried also in first instance to update to 1.3.2
In the log file are entries about expired certificates and it looks like that is the reason for failing the update.
Postato : 06/01/2023 7:00 pm
Rene
 Rene
(@rene)
Utenti
RE: SL1 FW update failes due to invalid certificate
I reverted to original FW.
But the maximum I can install is 1.3.0 via USB stick or Network.
Postato : 06/01/2023 9:21 pm
Hello
(@hello)
please post full log
Postato : 06/01/2023 10:21 pm
Rene
 Rene
(@rene)
Utenti
log.CZPX4819X009XC02705.2023-01-06_19-45-30
Postato : 06/01/2023 10:28 pm
Hello
(@hello)
thank you
Postato : 06/01/2023 10:30 pm
1 persone hanno apprezzato
Hello
(@hello)
so you have gone onto the screen and gone check for updates etc
Rene
 Rene
(@rene)
Utenti
Macintosh, do you guess the SD-Card is wrong formatted?
Postato : 06/01/2023 10:32 pm
Hello
(@hello)
posibbly the sd card could be wrong formated
Postato : 06/01/2023 10:33 pm
Hello
(@hello)
do you have another sd card and have you done it via wifi
Hello
(@hello)
https://help.prusa3d.com/article/firmware-updating-sl1-sl1s_124776
Postato : 06/01/2023 10:34 pm
Hello
(@hello)
by the looks of this installing `/run/sl1fw/update.raucb` failed: 1 it failed to read file
Jan 06 19:45:33 prusa64-sl1 nohup[281]: Data from the specified boot (-13) is not available: No such boot ID in journal
Jan 06 19:45:33 prusa64-sl1 nohup[281]: Data from the specified boot (-12) is not available: No such boot ID in journal
Jan 06 19:45:33 prusa64-sl1 nohup[281]: Data from the specified boot (-11) is not available: No such boot ID in journal
Jan 06 19:45:33 prusa64-sl1 nohup[281]: Data from the specified boot (-10) is not available: No such boot ID in journal
Jan 06 19:45:34 prusa64-sl1 nohup[281]: Data from the specified boot (-9) is not available: No such boot ID in journal
Jan 06 19:45:34 prusa64-sl1 nohup[281]: Data from the specified boot (-8) is not available: No such boot ID in journal
Jan 06 19:45:34 prusa64-sl1 nohup[281]: Data from the specified boot (-7) is not available: No such boot ID in journal
Postato : 06/01/2023 10:35 pm
Rene
 Rene
(@rene)
Utenti
The USB-Stick is new. I guess it has to be formatted FAT32? I'll try to copy the firmware with a Windows PC and retry
Postato : 06/01/2023 10:37 pm
Rene
 Rene
(@rene)
Utenti
The printer is connected via Wifi. I read about the issue with ethernet.
Hello
(@hello)
ok it does look like its looking for somthing but carnt find it
Postato : 06/01/2023 10:38 pm
Hello
(@hello)
follow this guide https://help.prusa3d.com/article/firmware-updating-sl1-sl1s_124776 and try it via wifi
Rene
 Rene
(@rene)
Utenti
Formatted the USB Stick under windows and copied the firmware on it. But it failed again. In the Firmware menu it only showes firmware 1.3.0 when I come from a factory reset (1.2.x). Tried this two times to install. One time via USB the other time via Wifi.
Postato : 06/01/2023 10:50 pm
Hello
(@hello)
Do you have sl1 or sl1 speed
Postato : 06/01/2023 11:04 pm
Rene
 Rene
(@rene)
Utenti
WTF, since last failed try to install the firmware I kept the printer switched on behind me. After some minutes I heard the fans spinning and klack klack and the display prompted to select language etc. And the left bottom on the lcd screen shows me 1.7.1 😀
Postato : 06/01/2023 11:05 pm
Hello
(@hello)
You may be flashing rong fermware
Hello
(@hello)
That's good .aybe
Postato : 06/01/2023 11:09 pm
Pagina 1 / 2
