[Solved] SL1 failed to update to 1.4.2
UNandUP
(@unandup)
Prusa SL1 firmware 1.4.2 failed to update. 100% success during fetch but failed afterwards.
Any help would be appreciated.
Napsal : 20/10/2020 5:58 pm
UNandUP
(@unandup)
RE: SL1 failed to update to 1.4.2
Here was a solution after speaking with support. Our wifi was disabled because we were using an ethernet connection. I unplugged it and activated wifi, which successfully connected and updated the SL1 from v1.2.3 to v1.3.0. For some reason the ethernet connection could not access the same update. Once I did that, I was able to update to v1.4.2 using the USB drive. So, v1.2.3 cannot go to v1.4.3.
Napsal : 21/10/2020 2:25 pm
