SL1 display life time 500h?
Piranha
(@piranha)
In the Facebook group someone said the LCD displays have 500h life time. Can someone confirm that?
Veröffentlicht : 10/02/2020 3:57 pm
rmm200
(@rmm200)
RE: SL1 display life time 500h?
Here is a general link to LCD life times:
http://www.hantronix.com/page/index/resources/life_expectancy
Facebook is only a slight step up from Reddit as a technical reference source.
Veröffentlicht : 10/02/2020 4:50 pm
Crawlerin
(@crawlerin)
Posted by: @robert-rmm200
OP probably means LCD panel that sits under the vat, not front LCD panel.
Those displays are consumables because they degrade very fast due to strong UV light source right underneath it and heat generated by UV lamps/diodes. General life expectancy is several hundred hours, how much is hard to say and every manufacturer has different numbers. Peopoly and Zortrax has 400 hours on theirs, while other say 700 or 1000. 500 hours  is about normal and I do not have access to that section of the shop (I don't own SL1) but that number should be on their webpage as well.
Diese r Beitrag wurde geändert Vor 6 years von Crawlerin
Veröffentlicht : 10/02/2020 9:02 pm
rmm200
(@rmm200)
Good clarification! Thanks!
Veröffentlicht : 10/02/2020 9:17 pm
canoniho-1
(@canoniho-1)
Posted by: @crawlerin
Thanks for the clarification
It was much needed. Love your simplistic style of explanation. 🙂
MyPrepaidCenter
Veröffentlicht : 05/03/2020 3:58 am
maiami
(@maiami)
I have very little faith in this fact.
https://spribe-aviator.net/
Veröffentlicht : 04/04/2023 7:42 am
