Rocking resin vat
vu.h
 vu.h
(@vu-h)
Rocking resin vat
In the calibration process, the step that requires you to take the resin vat and place it 90 degrees on the platform. When I do this, the vat has a little bit of a rock to it prior to me even adjusting the tilt bed. When I adjust the tilt bed to be flash with the bottom of the tilt bed, only one side is flash. The other side of the tilt bed is not flash. My prints come out fine as long as I have the object in the center. But if I do a larger print that covers the print platform, one side always never adhere to the platform.
I am in the process of contacting Prusa, but I just wanted to see if others have the same problem. And if there is an easy fix.
Publié : 19/10/2019 1:47 am
