Resin sensor - resin level too low
sasa.m2
(@sasa-m2)
Hi!
For the last few days I'm having problems with resin sensor on my SL1. As the topic title states: resin is too low.
I thought there is broken wire that goes from the vat to the resin sensor, however, when I touch vat with my finger during lowering of the platform, resin sensor triggers normally. For now I'm triggering it by hand until better solution.
It seems to me as if resin is not conducting (doubt it) or the platform has no connection to the ground? (Schematic shows proximity detection is used for resin level detection)
Thank you in advance
Best regards
Best Answer by sasa.m2:
It appears that problem solved itself. Suddenly it is working as it should.
Probably a temporary glitch.
Best regards
Postato : 06/07/2020 6:52 am
sasa.m2
(@sasa-m2)
RE: Resin sensor - resin level too low
Best regards
Postato : 08/07/2020 6:03 am
