Rear fan error
Piranha
(@piranha)
Rear fan error
I assembled the SL1 kit myself and everything works except for the "rear fan failed" error.
Support only helped me with the advice to check the fan continuity with my multimeter, and there is continuity.
Any ideas?
Veröffentlicht : 23/08/2019 3:52 pm
Blargedy
(@blargedy)
RE: Rear fan error
They wouldn't stay in chat for longer after you checked continuity?
What I can suggest is to check voltages on the fan headers when the SL1 is running but no fan connected. Else you could try another fan of the same voltage? Either way I'd contact support again and give them the result of your continuity test.
-Berni
Veröffentlicht : 30/08/2019 5:24 pm
