Prusa SL1 wiping USB drive
STO
 STO
(@sto)
I've discovered something rather annoying: if I insert a USB drive into the SL1 and start it up, it will completely wipe the drive. This happens whether I insert it into a "cold" machine, or a machine which had just been running and had automatically shut off when the print was completed. If I don't remember to pull the drive before starting the machine to do the next job, it'll wipe it.
Any reason for this? Any fix?
Opublikowany : 12/11/2019 6:59 pm
91d3on Mining
(@91d3on-mining)
RE: Prusa SL1 wiping USB drive
I noticed this happened to me as well. I only put one file on it, the calibration gcode, then I saw there are three already saved internally on the printer. After a couple uses I noticed the file I put on there was gone.
Opublikowany : 26/11/2019 9:26 pm
