Prusa SL1 Error Message "UV LED Fan Failure"
Hello everybody, I am the proud owner of a SL1 for 2 weeks.
I printed perfect models and I am very happy with the machine.
3 days ago a error message showed up 2-3 Minutes after I started a new print. It says the LED fan failed. So did the print.
I have the pictures on Imgur: https://imgur.com/a/aCj9m4u
I cleaned everything, uploaded newest Firmware but all prints fail.
Selftest says everything is OK. The error message never showed up again.
It seems to me that the LED lights do not work right. Maybe overheating as the error said.
Printer is in my garage at 21°C so temperature should not be the problem..
Prints go for 2-5mm then fall into the resin. Probably for not curing the 1st layer good enough.
What can I do, what have to be done to solve the problem.
Has somebody experienced the same problem?
Printer is SL1 /CW1 Bundle factory assembled.
On https://help.prusa3d.com the "Contact"-Button does not work an I can't send them the error message.
RE: Prusa SL1 Error Message "UV LED Fan Failure"
You can find a replacement LED unit in the store.
There are no instructions to change the unit yet, but maybe this can be deduced from the assembly instructions.
But I assume you will get a new one on warranty. The fastest way to contact Prusa is via chat. You will find the button on the shop page at the bottom right if you are logged in.
Danke lichtjaeger,
dann versuch ich mal morgen den chat. Gibt es einen Test um die UV Unit zu testen?
Ich kenne nur den LCD Test der dann das Logo zeigt.
@peter-i8 Es schaltet die UVLEDs an werend den LCD Test. Wenn man das Logo sieht, gehen die UVLEDs und der LCD panel.
Entschuldige bitte mein schlechtes Deutsch, ich spraeche haubsechlich Englisch.
