Prusa Magnetic Propeller/Stirrer
Vincent
(@vincent)
I ordered a spare CW1 Stainless Steel Tank on Black Friday, along with another MK3S.  I would like to switch the tanks out and have the magnetic propeller/stirrer remain in the tank.  Spares aren't available on the shop website.  The print isn't available in the printable part support section.  Is there a way to print a spare?  I am aware that there is an embedded magnet.
Respondido : 05/12/2019 2:09 am
RE: Prusa Magnetic Propeller/Stirrer
Hi Vincent,
there are 6 embedded magnets and a 7mm Ball bearing, and the STL's are in the CW1 printable parts download
regards  Joan
Original-Prusa-CW1
Respondido : 05/12/2019 6:52 pm
Lichtjaeger
(@lichtjaeger)
The magnets are 2mm x 6mm x 20mm. Pay attention to the orientation. For the lastest part models look into the repo.
Respondido : 06/12/2019 7:16 am
Nigel Johnson
(@nigel-johnson)
What can you glue the 2 halves together with? Can't think of anything that's solvent friendly? Thanks 🙂
Respondido : 13/04/2020 1:01 pm
Lichtjaeger
(@lichtjaeger)
I used some instant glue (Cyanoacrylate). Also, I used my 3D pen to fill the seam and my soldering iron to clean up and weld them together.
Respondido : 13/04/2020 2:43 pm
1 les gusta
