Prusa Magnetic Propeller/Stirrer
I ordered a spare CW1 Stainless Steel Tank on Black Friday, along with another MK3S. I would like to switch the tanks out and have the magnetic propeller/stirrer remain in the tank. Spares aren't available on the shop website. The print isn't available in the printable part support section. Is there a way to print a spare? I am aware that there is an embedded magnet.
RE: Prusa Magnetic Propeller/Stirrer
Hi Vincent,
there are 6 embedded magnets and a 7mm Ball bearing, and the STL's are in the CW1 printable parts download
The magnets are 2mm x 6mm x 20mm. Pay attention to the orientation. For the lastest part models look into the repo.
What can you glue the 2 halves together with? Can't think of anything that's solvent friendly? Thanks 🙂
I used some instant glue (Cyanoacrylate). Also, I used my 3D pen to fill the seam and my soldering iron to clean up and weld them together.
