Print size 120 mm
Peter
(@peter-6)
Print size 120 mm
The SL1 specs say : 120 mm wide
In prusa slicer the max width is 118 mm
In slicer (expert mode) I try to change this to 120 mm but this is not accepted bu prusa slicer.
So what is the max width we can print with the SL1? 120 or 118 mm?
Need to print something 120 mm wide. That’s why😄
This topic was modified 6 years temu by Peter
Opublikowany : 26/09/2020 10:20 pm
RE: Print size 120 mm
Not sure - might be a bug.  I would post it on github.
https://github.com/prusa3d/PrusaSlicer/releases
Opublikowany : 29/09/2020 4:00 pm
Here to be exact:
https://github.com/prusa3d/PrusaSlicer/issues
