Odd Resin Curing Situation
Ghost Raptor
(@ghost-raptor)
I have run into an odd issue 3 times in a row now.
I did a print that have I have done before, but when checking it looks like it failed....Several layers on the print surface, several layers on the FEP. Ok, I'll try again...same thing. At this point I noticed that it was covering almost the whole print area, mind you I only had items covering 1/4 to 1/3 of the print surface. I tried a third time with a small base for a mini...same issue, build plate has most of it covered in a large rectangle and big chunks of cured resin on the FEP.
I thought there might be an issue with the display, but when I run the test, I can see the Prusa logo and LED below just fine. I'm really confused what's going on.
FYI, my LCD screen is cracked, but I have been able to print with it just fine for several months now (yes I'm getting that replaced), so I'm not sure that's the issue here.
Any help would be appreciated.
Napsal : 22/04/2020 2:43 am
