Method to clear internal storage - SL1s
abruno
(@abruno)
Is there a faster way than individual deletion of files from the SL1S?
Theoretically I could delete them from the web interface but it throws an error and does not allow that to occur either.
Opublikowany : 22/04/2023 6:10 am
tsamisa
(@tsamisa)
RE: Method to clear internal storage - SL1s
I have the same problem with the web ui. I contacted Prusa and after a bit of a hassle (they just ignored me for a couple of times) they admitted that is a known issue and its "probably" going to be solved on the next update. But it seems that it works for me know if i use an updated chrome. I can finally delete files via the web interface. True deleting by swapping on the touch screen is not practical and half of the time it goes to the print screen.
Opublikowany : 03/05/2023 11:31 am
