Loud banging noise
Nushaer Abrar
(@nushaer-abrar)
Loud banging noise
Whenever I try printing a model, after 10-15 layers, the printer starts doing a loud hammering noise. After some time, I cancelled the print and I noticed the print bed was unusually hot. For the nature of my research, I require using high temperature resistant resin. I am using the ANYCUBIC RIGID 100 resin for this. I have tried several exposure settings, and none have solved this issue so far. I also tried recalibrating the printer but to no avail. I bought this printer a few months ago and I am positive there is no resin blocking the tilt platform sensor. Any help on this would be appreciated. You can watch this Video for reference.
Printing parameters:
initial layers: 20
Layer height: 0.05 mm
Initial Exposure: 25s
Layer exposure: 2.5s
printing profile: slower
Opublikowany : 14/03/2025 11:04 pm
RE: Loud banging noise
You probably need to contact Prusa Support via chat; but first:
https://help.prusa3d.com/article/sl1-sl1s-maintenance_1951
Opublikowany : 15/03/2025 6:18 pm
