Layer Time less than 1s
Aaron
(@aaron-4)
I've a very reactive resin that needs a short cure time but I can't set the layer time to less than 1s in prusa slicer.
Does anyone know a work around?
or is this a physical limit?
Thanks in advance for any help!
A bit slow, but I get there in the end.
Respondido : 18/07/2023 2:10 pm
Mateus Mota Morais
(@mateus-mota-morais)
Miembro
RE: Layer Time less than 1s
It seems that you can change the minimum time limit (you need to set prusa slicer in advanced mode).
In the Printer Settings --> Exposure --> Minimum exposure time
However, I do not know if the 1s limit is set for a mechanical reason also (maybe to limit the go back and forth speed which could reduce the life of the machine, or to avoid vibrations).
So it is possible to work it around, but maybe you will face some problems.
Another alternative is reducing the layer thickness keeping the same time. The resolution will increase, but also the printing will take much longer.
Respondido : 01/08/2023 12:22 pm
