Is calibration between resin tank and/or build plate switch necessary?
Cannot seem to find the answer anywhere.
1) Do I need to re-calibrate if I swap the resin tank out for different color?
... I am guessing no
2) Do I need to re-calibrate if I change to a different build plate?
... I am guessing yes
Has anyone tested?
This topic was modified 5 years temu by kman344
Opublikowany : 23/10/2021 2:34 pm
On my SL1 I have swapped tanks and platforms without re-calibrating and have had no issues. I can't say for sure if it's supposed to work that way though.
Opublikowany : 25/10/2021 6:17 pm
Topic starter
answered:
RE: Thank you.
Thank you for the information, gnat!
This post was modified 5 years temu by kman344
Opublikowany : 27/10/2021 12:04 pm
