I started getting "marks" on my print after having a leak due to a hole in my FEP foil
Piranha
(@piranha)
My display test is fine. No dead pixel. At least I dont see them. I'm getting these marks on my prints anyways. My LCD screen is clean, as my FEP foil.
I had a hole in my previous FEP foil which lead to a leak. I cleaned off that leak but I'm worried it damaged the LCD screen somehow.
I printed one of these plates that I designed for this purpose to locate the marks. When I turned it 180 degree and printed it again, the marks also turned 180 degree.
Did anyone encounter this problem?
I'm about to take the SL1 apart and look for the cause.
https://imgur.com/a/xn4WpVF
Ce sujet a été modifié il y a 6 years 3 fois par Piranha
Publié : 22/11/2019 2:18 pm
Piranha
(@piranha)
RE: I started getting "marks" on my print after having a leak due to a hole in my FEP foil
EDIT: I found the solution! Resin leaked between LCD screen and the protective glas on top.
Publié : 22/11/2019 4:09 pm
