How to erase files from internal memory?
Hagelstone
(@hagelstone)
Hi!
How can I erase files from SL1 internal memory, which i have uploaded to SL1 via Slicer?
Greatings
Michael
Napsal : 22/05/2019 2:57 pm
Blargedy
(@blargedy)
RE: How to erase files from internal memory?
I haven't been able to find this either. It would seem it is not an option. Even a factory reset doesn't erase internal memory. I recommend opening a feature request on the slicer github, since as far as I can tell, there is no feature request options directly for the SL1. Seems like a massive oversight, or an impractically hidden function.
-Berni
Napsal : 30/08/2019 5:16 pm
JohnF
(@johnf)
Go to print a file, swipe on the file and hit the trash can icon.
Napsal : 04/09/2019 12:34 am
2 lidem se líbí
Pete Brown
(@pete-brown)
Posted by: @john-f29
Thank you for posting this. I couldn't find it anywhere in docs, site, etc.
It's annoying when you want to delete a whole bunch of files (it scrolls to the top each time) but it works.
Pete
Napsal : 22/02/2020 9:27 pm
Nigel Johnson
(@nigel-johnson)
Has there been a change in the firmware (I'm running 1.3.0 and although it says 1.3.3 is on the site, the SL1 won't pick it up automatically so I'm not overly bothered)? When I swipe to print I only have a button to change the exposure and the play button to print. This happens on all of the files there.
Napsal : 31/03/2020 1:18 pm
Nigel Johnson
(@nigel-johnson)
Found it. It's the file list menu that has the swipe. Sorry.
Napsal : 01/04/2020 11:30 am
