Disable tilt mechanism for many small parts
thelgmaster
(@thelgmaster)
Hi all,
i love my SL1S, but always when i print many small parts at the same time, it seams,
that the tilt machenism isn't enough when the fep-foil is not tight enough (after many prints).
bigger prints get just fine.
smaller pints i need to move to the corners of the print plate, where the fep-foil is still tighten enough.
so here is my strange question:
is there an option to disable the tilt of the resin tank?
--> remove cured layers just by getting higher with built plate slowly (like most cheap resin printers)
Postato : 14/11/2022 6:09 pm
