CW1 - Shortcut to switch between dry and cure?
AndrewH
(@andrewh-2)
Is there a shortcut (preferably a couple of clicks) to switch between the drying and curing processes on the CW1?
Easy to switch between washing and whichever of the above was last used, the container does that automatically. But to switch from drying to curing or vice versa, you have to go into settings and drill down  to function, twist the knob to select cure/dry, click and then navigate back up the menus. Tedious.
Thanks for suggestions.
Best Answer by Lichtjaeger:
Hold the knob for fast access.
Opublikowany : 28/11/2019 7:22 pm
1 ludzie polubili
Lichtjaeger
(@lichtjaeger)
RE: CW1 - Shortcut to switch between dry and cure?
Opublikowany : 28/11/2019 7:29 pm
1 ludzie polubili
AndrewH
(@andrewh-2)
Ahh, thanks lichtjaeger. Works a treat.
Opublikowany : 29/11/2019 4:59 pm
