CW1: Increased max drying time
I use a water washable resin and have found that I've been needing to do 3 10 minute drying cycles to get my parts properly dry before curing. Unfortunately the max allowable drying time is 10 minutes which meant having to come back and start multiple cycles and then switch back to include a curing cycle.
So I bumped the firmware to increase the max allowed time to 60 minutes. What I don't know, however, is if there was a reason for the 10 minute limit (e.g. duty cycle on the heater), so use it at your own risk until Prusa weighs in and merges (or not) my PR.
Opublikowany : 15/11/2020 5:15 am
RE: CW1: Increased max drying time
Have you thought about chatting with support? I searched the forum and manual and could not find an answer for you.
Opublikowany : 28/11/2020 7:06 pm
