Can a bad FEP film cause resin sensor problems when calilbrating
Colin Hamilton
(@colin-hamilton)
I'm a complete rookie at this. I'm trying to print one of my own models in Orange resin, and basically it won't print. All I'm getting is a shadow of the shape stuck to the FEP film. I decided to calibrate again and got the Resin Sensor warning. I followed the instructions, but still get the same message.
Could it be the FEP film?
Colin Hamilton
Opublikowany : 14/01/2025 6:56 pm
drac
 drac
(@drac)
RE: Can a bad FEP film cause resin sensor problems when calilbrating
I don't think so.
Check the bottom edge of the resin tank to see if there is a thin layer of resin build up, also check the plate the resin tank sits on.
Opublikowany : 08/04/2025 6:15 pm
