Add a Delay Before Layer Exposure?
WidgetCeramics
(@widgetceramics)
Is it possible to add a 1 or 2 second pause after the vat tilts back to the level position, immediately before exposing the next layer? This would be similar to the "Light Off Delay" setting in Chitubox slicer. I am working with very viscous resin. In my experience, adding a 1 or 2 second light-off delay before expositing the next layer allows the resin to settle so that it's not flowing while being exposed to UV.
Postato : 19/10/2021 2:26 pm
Tiger3DPrinting
(@tiger3dprinting)
RE: Add a Delay Before Layer Exposure?
isnt that kinda what the speed setting does in the print settings portion while its printing? slower and faster, where faster is default and slower I believe slows down the tilt back after layer peels to let resin fill back in
Postato : 08/12/2021 2:31 am
Tiger3DPrinting
(@tiger3dprinting)
sylviatrilling
(@sylviatrilling)
Material Settings > Material Printing Profile: Print Speed: Slow. The hint for 'Slow' says that it does pause after tilt and before the next layer is exposed to allow the resin to settle. It doesn't say for how long or give you any option the set the length of time it pauses.
Mk3S+,SL1S
Postato : 12/12/2021 4:02 pm
