Tolerances across the build plate
meekfred
(@meekfred)
I am considering the purchase of a SL1
I currently have a photon and a photon s but I find that when I print a plate full of small components they vary across  the plate on the xy axis by as much as 0.15mm
Do you think that this problem will go away for me if I purchase a SL1?
Opublikowany : 04/07/2020 12:35 pm
ScoutStorm
(@scoutstorm)
Bioluminous
RE: Tolerances across the build plate
I have both the Photon and the Photon S as well as the SL1. I haven't had that variance on the S or the SL1. The Photon S has a better linear bearing. I think the bearing on the SL1 is better quality. Overall, the build quality of the SL1 is superior. Very similar output to the Photon S though.
Opublikowany : 07/07/2020 12:55 am
