PrusaSL1Viewer - SL1 analyzer, healer and validator
Tiago
(@tiago)
Open, view, edit, extract, convert, mutate and island checker for DLP files generated from Slicers.
The tool you should always use before actual print your file, it can find flying pixels and attempt to fix them. Avoid cured resin on vat 🙂
Project: https://github.com/sn4k3/PrusaSL1Viewer
Download: https://github.com/sn4k3/PrusaSL1Viewer/releases
Features
  • View image layer by layer
  • View and extract thumbnails
  • View all used settings
  • Edit print properties and save file
  • Mutate and filter layers
  • Check islands and repair/remove them
  • Export file to a folder
  • Convert SL1 format to another format
  • Portable (No installation needed)
PS: Previous posted here with changelogs: https://forum.prusa3d.com/forum/prusaslicer/prusasl1viewer-open-view-extract-and-convert-sl1-files-generated-from-prusaslicer/
Respondido : 10/06/2020 4:56 am
1 les gusta
Tiago
(@tiago)
RE: PrusaSL1Viewer - SL1 analyzer, healer and validator
New version 0.5:
  • (Add) PWS and PW0 file formats (Thanks to Jason McMullan)
  • (Add) PrusaSlicer Printer "AnyCubic Photon S"
  • (Add) PrusaSlicer Printer "AnyCubic Photon Zero"
  • (Add) PrusaSlicer Universal Profiles optimized for non SL1 printers (Import them)
  • (Add) Open image files as single layer and transform them in grayscale (jpg, jpeg, png, bmp, gif, tga)
  • (Add) Resize mutator
  • (Add) Shortcut "F5" to reload current layer preview
  • (Add) Shortcut "Home" and button go to first layer
  • (Add) Shortcut "End" and button go to last layer
  • (Add) Shortcut "+" and button go to next layer
  • (Add) Shortcut "-" and button go to previous layer
  • (Add) Shortcut "CTRL+Left" go to previous issue if available
  • (Add) Shortcut "CTRL+Right" go to next issue if available
  • (Add) Shortcut "Delete" to remove selected issues
  • (Add) Button to jump to a layer number
  • (Add) Show current layer and height near tracker position
  • (Add) Auto compute issues when click "Issues" tab for the first time for the open file
  • (Add) "AntiAliasing_x" note under PrusaSlicer printer to enable AntiAliasing on supported formats, printers lacking this note are not supported
  • (Add) AntiAliasing capable convertions
  • (Add) Touching Bounds detection under issues
  • (Change) Scroll bar to track bar
  • (Change) Keyword "LiftingSpeed" to "LiftSpeed" under PrusaSlicer notes (Please update printers notes or import them again)
  • (Change) Keywords For Nova3D Elfin printer under PrusaSlicer notes (Please update printers notes or import them again)
  • (Change) Keywords For Zortrax Inkspire printer under PrusaSlicer notes (Please update printers notes or import them again)
  • (Change) Islands tab to Issues ab
  • (Improvement) Much faster photon, cbddlp, cbt and phz file encoding/convert and saves
  • (Improvement) Much faster layer scroll display
  • (Improvement) Hide empty items for status bar, ie: if printer don't have them to display
  • (Improvement) Smooth mutators descriptions
  • (Improvement) Disallow invalid iteration numbers for smooth mutators
  • (Improvement) File reload now reshow current layer after reload
  • (Improvement) Some dependecies were updated and ZedGraph removed
  • (Fix) AntiAlias decodes for photon and cbddlp
  • (Fix) AntiAlias encodes and decodes for cbt
  • (Fix) Save the preview thumbnail image trigger an error
  • (Fix) Implement missing "InheritsCummulative" key to SL1 files
  • (Fix) Install print profiles button, two typos and Cancel button doesn't really cancel the operation
Respondido : 13/06/2020 4:39 am
1 les gusta
