SL1S Potential Bug: print surface too big causing Tilt Homing Failed
V2arK
(@v2ark)
Utenti
Hi!
I was printing a sphere and about this height, I encountered Error #10101, Tilt homing failed.
I googled online it says that possibly the connecting rod for the tilt mechanism is broken (resistance to move). I checked it and there is nothing wrong. So I assume it's the surface of the printing being too large, making the tilt motor using too much current and triggered this error. Is there any way around this? (like fast tilt / tilt? will it solve this issue?)
Or is this a corner case in the firmware that needed to be addressed?
Thanks!
Questa discussione è stata modificata 2 years fa da V2arK
Postato : 08/03/2024 12:15 am
ACop
 ACop
(@acop)
Utenti
RE: SL1S Potential Bug: print surface too big causing Tilt Homing Failed
Any developments here?
Thanks!
Posted by: @v2ark
Hi!
Thanks!
Postato : 19/04/2024 7:27 am
assp
 assp
(@assp)
Utenti
I have the same issue, did you find a solution?
Currently I have done a lot of testing to find the problem, but I don't get annywhere.
Postato : 06/08/2024 11:04 pm
