[Épinglé] Important links for the Prusa SL1
Same Old Shane
(@same-old-shane)
Membre Admin
Hello all;
With our Original Prusa SL1/SL1S, we have collected some important links and provided them here in one location. If there are other links that we should list here, please feel free to let us know.
It is very important to learn the difference between the Original Prusa SL1 and SL1S, as they aren't the same printers!
  • The SL1 uses an older LCD screen and has a smaller build volume than the SL1S
  • The SL1S uses a different (monochrome) LCD screen has a different print volume. The printer is easily identified on the front of the printer will be the name (SL1 or SL1S).
Please keep this mind! Flashing incorrect firmware will cause issues with the the printer and could damage it!
Homepage for The Original Prusa SL1/SL1S
Did you know that each printer we produce has its own main section in our knowledge base? It is your one stop location for links to everything you will need for your printer including:
  • Firmware
  • Drivers & Apps (includes PrusaSlicer)
  • Printable parts
  • Assembly manuals
  • 3D printing handbook
  • Helpful articles and guides
  • ...and a lot more
Example of the homepage for the SL1S
Homepages for the printers:
Printable 3D models:
Example models (verified G-codes) that are shipped on the SD card are also provided in our drivers and app package and can be downloaded as a part of the Drivers & Apps package, which is available here:
prusa3d.com/downloads
If you want to explore a lot more designs that our community has submitted, make sure to head over to www.printables.com and explore hundreds of thousands of designs.
PrusaLink (beta)
Is currently in a work in progress status, you can monitor and control your Original Prusa SL1/SL1S over your local network. Make sure to check back for any announced updates to PrusaLink.
E-SHOP & Spare parts
VIDEOS:
The Original Prusa SL1S SPEED
SL1 Calibration Walk through
How to replace the FEP foil on the SL1
How to slice 3D objects for the Original SL1
Shane (AKA FromPrusa)
Publié : 19/11/2020 12:36 pm
1 personnes ont aimé
