i search a Member with a SL1 who can print for me an 3D-Part
maru
 maru
(@maru)
Hi there,
i am Maru from switzerland. i thinking about buying a Prusa SL1 (or an Formlabs 3...). i need it for HF-Antennas and for this antennas i need a precision of 0.01mm in Z-axis. X/Y is not so important...
Formlabs i ask to print for me this part, for i can look to buy this Printer or no... (200Dollar with shipping because its USA)
But PRUSA dont have this service. Is outside there any person who can print me this Part with an SL1 and the maximum Z-resolution? Say me, what you get, i need to look both parts from both printers to choose the right printer.
the Part i can send via email.the borderlines are 36mm * 36mm * 61mm
sorry for my bad english, greeting Maru
Veröffentlicht : 18/06/2021 9:28 am
Lichtjaeger
(@lichtjaeger)
RE: i search a Member with a SL1 who can print for me an 3D-Part
You can use PrusaWorld to look for someone who fits your needs. Just set the filters to "Print on demand" and "Prusa SL1".
I can do too. (living in Germany)
Veröffentlicht : 18/06/2021 9:55 am
maru
 maru
(@maru)
Hallo Lichtjäger,
das ist super! schick mir deine email, dann schick ich dir das Step-file. Wichtig ist die maximale Auflösung in Z, was geht. ich hab im internet was von 0,01mm gelesen aber beim SL1 steht 0,025mm. was stimmt jetzt? der formlab 3 kann auch nur 0,025...
die struktur selbst wäre mit 0,025mm ok aber die Position in Z sollte genauer sein (positionierungsbahnen für Drahtwicklungen). Rein rechnerisch machen da abweichungen von 1/1000 schon grosse unterschiede aber man muss realistisch bleiben...
Danke dir, Gruss Maru
Veröffentlicht : 18/06/2021 10:07 am
maru
 maru
(@maru)
Hello Lichtjäger,
that's great! send me your email, then I will send you the step file. What is important is the maximum resolution in Z, which is possible. I've read something of 0.01mm on the internet, but the SL1 is 0.025mm. what's right now? the formlab 3 can also only measure 0.025 ...
the structure itself would be ok with 0.025mm but the position in Z should be more precise (positioning tracks for wire windings). In purely mathematical terms, deviations of 1/1000 make big differences, but you have to be realistic ...
Thank you, greetings Maru
Veröffentlicht : 18/06/2021 10:53 am
Hi Maru,
May I ask which antenna you are making?
73,s
Joan
G8XZZ
Veröffentlicht : 18/06/2021 12:50 pm
maru
 maru
(@maru)
Hi JoanTabb
its a shielded HF-Antenna for a z-axis magnetic field (amateur radio equipment).
Lichtjäger help me to struggle out, what printer is for my requirement better 👍
greeting Maru
Veröffentlicht : 21/06/2021 5:25 pm
