Height range modifier for SL1 (Feature request)
gyroscopes
(@gyroscopes)
I have a part that has a few layers that need to be printed in the SLOW mode rather than FAST. e.g. the tilt needs to be slower just for say 10 layers out of 1000.
Basically 1% of the layers needs to be printed SLOW.
height range modifiers are a nice feature for FDM printers in Prusa slicer but it is missing from the SL1.
I figured that I would just edited the G-code. But looking at the SL1 it does not use G-CODE just image files and an initial setup configuration.
height range modifiers would be useful for
  • Changing the tilt speed
  • Pauses
  • Layer height changes (thicker/thinner layers)
  • Exposure times
Publié : 26/08/2024 3:50 pm
The forums are user to user.  Devs very rarely ever check in or respond here.
Feature requests need to be made at the appropriate Prusa github project.  This one might require both a change to Prusa Slicer and a change to the Sl1 firmware as it may only load the speed settings in at the start.
The PS github is located here https://github.com/prusa3d/PrusaSlicer/issues   and the SL1 is located here https://github.com/prusa3d/Prusa-Firmware-SL1/issues
Before opening new ones please do search using any appropriate keywords for related ones.  For example
https://github.com/prusa3d/PrusaSlicer/issues/4976   requests different layer thickness in the same model.
Publié : 26/08/2024 5:28 pm
gyroscopes
(@gyroscopes)
RE: Height range modifier for SL1 (Feature request)
I will have a look now to see if anyone has requested it. Would be interested to hear if anyone else has this requirement.
Publié : 26/08/2024 9:24 pm
