flexible resin
Matt
 Matt
(@matt-15)
flexible resin
Hi all, What has your experience been like with the Prusa flexible resin? I would like to try and get a semi flexible resin for my prints, but was wondering if I could add a dye to this to get different colours for example too or maybe mix it with the prusa tough resin to get a semi flexible print if possible? Thanks!
Postato : 11/07/2020 11:16 am
RE: flexible resin
Hi Matty,
with the correct dye's you can tint Resin for the SL1!
 I tinted Opaque Orange, to make a greeny colour.
I have successfully added flexible resin to tough resin and ended up with semiflex...
I have added clear resin to tinted resin and ended up with semi translucent resin
Initially I bought  the Monocure tinting kit
https://www.amazon.com/Monocure-3D-Pigment-Printer-Resins/dp/B07G1ZBDBX
I have also used Chinese tints with success
Regards Joan
Postato : 11/07/2020 5:13 pm
Matt
 Matt
(@matt-15)
RE: flexible resin
Posted by: @joantabb
Hi Matty,
Regards Joan
Hey Joan,
Thank you for the reponse, thats awesome! 😀
I will have to get mixing then! What kind of flexible resin did you use to get the semi flex result? I was would be using the prusa tough resin and then either the clear flex resin by prusa or the Monocure flex 100, would both of these be fine for mixing do you think, and did you have to change the stock curing times as a result of mixing?
I have only just recently got my SL1 so still learning 🙂
Thanks!
Postato : 11/07/2020 9:11 pm
RE: flexible resin
@mattyice
I used a Chinese flex, because it was low cost and available...    bought it a long time ago so don't recall it's name.
Other users say Flex 100 is good. I have not used it.
I think low temperature has more effect on needing  longer initial cure time, I guess if you went to high numbers for admix items (dye's and powder pigments), you might need to  increase the initial cure time.
I try to be sensible and tint colours rather than colour resins...    if you want black resin, Clear is probably not the best starting point! 🙂
Postato : 11/07/2020 9:32 pm
Wilko
(@wilko)
RE: flexible resin
@joantabb "I have successfully added flexible resin to tough resin and ended up with semiflex... "
Would you mind sharing what the amount of flex was that you added to standard tough resin?
I've been playing with Prusa Azure Blue, Tough Black and Anycubic Black this past week, finally starting to get pretty consistent quality prints, but they are way too brittle for my liking. Would adding 10% flexible resin to standard resin be enough of a change to change that, or did you add more?
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Postato : 13/01/2021 7:42 pm
