FLEX THIRD PARTY RESIN
Did anyone use any FLEXIBLE third party resin?
RE: FLEX THIRD PARTY RESIN
I have done a little with eSun's eResin-Flex. It smells terrible (compared to the Elegoo water washable resin I otherwise use), needs long exposures (I was using 60/20 for 0.1 layers if I remember correctly), and cures oddly. By curing oddly I mean that even after 60 minutes in the CW1 and another couple of hours under a stand alone 300w 405nm lamp it was still tacky to the touch like it had not been cured post wash. After leaving it over night (in a completely dark room with no UV), however, I found it perfectly cured and no longer tacky the next morning. A subsequent print I did my usual 10 minutes in the CW1 for the cure stage and found it perfectly cured the next morning.
I haven't used TPU in my FDM so I can't compare to anything, but it seems to fit the bill.
I use Monocure3D and PrimaValue.
