Firmware 2.1.3-FINAL for Original Prusa CW1
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi guys,
this is a final version of the firmware recommended to all users.
What is new?
All the CW1 machines were initially shipped with version 2.1.3.
Supported machines:
Original Prusa CW1
Download link:
prusa3d.com/drivers/
Firmware flashing guide:
https://manual.prusa3d.com/Guide/Upgrading+the+firmware/66
Please report any bug here:
gitlab.com/prusa3d/cw1
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Napsal : 03/06/2019 12:39 pm
patrick.v2
(@patrick-v2)
RE: Firmware 2.1.3-FINAL for Original Prusa CW1
I discovered that curing is not activated by default, only drying is. so I had to change the run mode to drying+curing in order to complete the after-print process successfully
Napsal : 25/08/2019 9:05 am
1 lidem se líbí
Pete Brown
(@pete-brown)
Not sure this is the right place for suggestions, but I would really like simple single-cycle runs easily accessible from the top menu or one menu deep.
Specifically, I'd like to be able to run a second heating or curing cycle without having to go through the menu and change the "run". The way it is right now is pretty hostile to that kind of use.
Pete
Napsal : 29/08/2019 6:26 am
1 lidem se líbí
patrick.v2
(@patrick-v2)
I totally agree with that
Napsal : 29/08/2019 7:09 am
1 lidem se líbí
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Guys, thanks for the feedback, forwarded to our devs.
Assembly manuals
/ Knowledge Base
Napsal : 03/09/2019 8:11 am
Milhooz
(@milhooz)
Ok I was not sure why my print were still a bit soft, in the CW1 manual the menu said Drying and Curing but on my display it was only saying Drying, I though they just changed the label but not that it was only drying. Thank to Patrick I was able to enable curing as well... By default it should be both I guess.
Napsal : 22/09/2019 9:11 pm
Lichtjaeger
(@lichtjaeger)
Posted by: @pete-b3
Pete
I already opened an issue on Gitlab. Maybe some upvotes would raise the priority for this.
Napsal : 23/09/2019 5:44 am
patrick.v2
(@patrick-v2)
I have another question regarding the drying operation: it displays the temp but what should this be ? it stays mainly at room temp but should it warm up more in order to dry ? I saw on some resin manufacturer site that objecys should be dryed at 65°C ...
Napsal : 24/09/2019 8:20 am
patrick.v2
(@patrick-v2)
I found out the pre-heat (before starting the drying) is disabled by default. But still not sure which temp to use (and for how long) - i found noting regarding the Prusa Resins
Napsal : 25/09/2019 10:08 am
