Calibration of resin tank
Luigi Galli
(@luigi-galli)
Miembro
I have the problem that after each print I have to calibrate the resin tank. In fact, if I check the alignment, I always find it altered. What could this depend on?
Some expert colleagues told me to abandon the plastic resin tank because it gives a lot of problems and mount the metal one, but on the site this accessory is not available.
Este debate ha sido modificado el hace 1 year por Luigi Galli
Respondido : 03/03/2025 8:08 pm
Ben Marshall Designs
(@ben-marshall-designs)
RE: Calibration of resin tank
When you say calibrate, what do you mean? I've not heard of this problem and I have multiple plastic tanks and they all perform as expected.
Respondido : 20/03/2025 2:46 pm
Luigi Galli
(@luigi-galli)
Miembro
Con calibrazione intendo dire che devo svitare la vite della piattaforma, svitare le viti del serbatoio, posizionare a 90 gradi e riallineare il serbatoio con il pannello, riavvitarlo al pannello e riallineare la piattaforma con il serbatoio, riavvitare la piattaforma, quindi riempire nuovamente il serbatoio di resina e infine procedere alla stampa.
Respondido : 20/03/2025 7:21 pm
