ABS Qualities with the SL1?
Hello everyone.
Is it possible to print things to ABS specifications with the SL1? What resin or materials would I use? I want to print in ABS but don't want the hazard of using it in my house, which is the only place I can operate a printer, like my Mk3.
Thank you.
RE: ABS Qualities with the SL1?
There is tough resin made for the SL1, and a few 3d printing youtubers have tested it out in comparison. however results will vary from resin to resin manufacturers.
Also, I don't see how FFD ABS is worse than resin based printers. Resin is more toxic and does emit more fumes than an ABS printer printing too hot.
@daniel-k5
Thank you. I was only recently aware of how resin based printers are more toxic. I hear a lot about the problems of ABS and SLA parts are produced in an enclosed environment. I came across Tough Resin, which looks like the resin with the highest tensile strength.
