3.1.0 Firmware for Original Prusa CW1/CW1S
Same Old Shane
(@same-old-shane)
Mitglied Admin
Hello all, We are pleased to announce a new firmware update for our CW1/CW1S. Below you will learn of the changes and download links are below. Please make sure to download the correct version as there are 2 different versions between the CW1 and CW1S.
Summary
  • Support for CW1S
  • Drying temperature increased (CW1S)
  • Drying session extended
  • Hold platform (new feature)
  • Improved translations
This is the final release of firmware 3.1.0, the first firmware release with support for both the CW1 and the new CW1S. Attention, the firmware is not universal, each device requires its own firmware file!
Support for CW1S
This release of the firmware brings support for the recently announced Original Prusa Curing and Washing Machine CW1S. The CW1S features a reworked heating system, which required a completely redesigned heating algorithm.
Attention! The CW1S requires a different firmware file than the CW1. Do not attempt to flash firmware intended for the other version. It might result in damage to the device!
As mentioned above, the CW1S brings reworked internals with the aim to improve its drying capabilities. This firmware release enables CW1S owners to increase the target temperature up to 60 °C. Note that the limit for CW1 is 40 °C.
Previously, the system allowed for a 10 minutes drying session. This is now extended to 60 minutes for both CW1 and CW1S.
Original Prusa CW1S brings a removable platform protected with an FEP film. Once there is a bigger amount of residue on the film, it might be necessary to replace it with a new one. To help align the platform back to its original position, the user can activate “Hold platform” from the menu.
The motor gets “locked” (rotation is disabled) by the system, temporarily allowing the user to align the platform properly. Once the platform is properly seated, exit the menu to “unlock” the motor.
Since there are some changes to firmware 3.1.0, the translators have rechecked all the language strings. Should you find any incorrect translations, please let us know.
Supported Euqipment; Original Prusa CW1/CW1S
Download link:
https://github.com/prusa3d/Prusa-CW-Firmware/releases/tag/v3.1.0
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware-SL1/issues
Shane (AKA FromPrusa)
Veröffentlicht : 20/07/2021 6:06 pm
Lichtjaeger
(@lichtjaeger)
CW1 -> CW1.5
I've found the upgrade guide.
Why do you guys speak of a CW1 to CW1S upgrade when the CW1S firmware is incompatible with the CW1?
The "real" CW1S has a new heating system.
It is a partial upgrade like the MK2 to Mk2.5 upgrade. So it should be called CW1.5 or CW1+.
Veröffentlicht : 22/07/2021 7:27 am
theo
 theo
(@theo-2)
Temperature while curing
Can it also provide the 60°C while curing? I spotted some resins (the Formfutura ones for example) that suggest curing the parts for 20-30 minutes at 65°C.
Veröffentlicht : 25/07/2021 10:02 pm
richard
(@richard-6)
upgrade path for cw1 to cw1s?
Posted by: @same-old-shane
Better yet, any plans to offer a CW1 to CW1S upgrade package like was done for the SL1- -> SL1S?  I have money, take it please.
It'd be nice when you guys do announcements of new stuff to also mention if there are any plans or possibility of upgrade paths.  When you don't mention it, it feels like an oversight.  I understand in some cases an 'upgrade' can basically mean replacing almost everything, but considering the two are the same footprint that likely means a chunk of the frame/etc wouldn't need replacing, so an 'upgrade' package would end up being cheaper.  Knowing if you guys plan an upgrade path at all, helps one decide if it is really worth it to purchase the entire new unit or not for the specific upgraded features (higher temp in this case).
Veröffentlicht : 17/09/2021 3:09 pm
