1.6.6 Firmware for SL1 and SL1S SPEED is out now.
Same Old Shane
(@same-old-shane)
Member Admin
Hello all;
We are happy to announce an update to the SL1 / SL1s, but please make sure to read the summary as this is a specific update addressing the changing of hardware parts.
Summary
  • Support for new rear fan
  • Support for new DAC converter
This is a final firmware release focused on support for new hardware due to parts shortages. Upgrading to this firmware is required only in case you are currently upgrading your SL1 to SL1S or replacing HW parts described below.
Version 1.6.6 is a direct successor to the previous final version 1.6.4. Version 1.6.5 was not released publicly as it was used for internal purposes only.
Our vendor started supplying new rear fan with slightly different specifications. Self-tests and RPM control in the firmware were adjusted to accommodate this change. There is no change from the user's perspective, only a slight audible difference. This adjustment in the firmware makes the new rear fan backward compatible with SL1 and SL1S SPEED.
Support for new DAC converters
There is a shortage of digital-to-analog converter (DAC) used on the boost board in the SL1S SPEED. This part is now replaced with an equivalent DAC, however, some changes to the firmware were required.
If you install this new revision of the boost board to a printer running firmware 1.6.5 or older, the system will display an error message #10320. To fix this issue, please install this firmware release 1.6.6.
Download location;
https://github.com/prusa3d/Prusa-Firmware-SL1/releases/tag/1.6.6
Firmware update instructions;
https://help.prusa3d.com/en/article/firmware-updating-sl1-sl1s_124776
Shane (AKA FromPrusa)
Posted : 14/04/2022 7:21 am
Lichtjaeger
(@lichtjaeger)
RE: 1.6.6 Firmware for SL1 and SL1S SPEED is out now.
I'm more interested in 1.7.0 with resin calibration support.
Are you still planning to upload a blog post for creating custom resin calibration files?
Posted : 14/04/2022 7:42 am
MikeH
(@mikeh)
I'd also like to hear Prusa's official position on providing calibration support for the SL1S.
Posted : 14/04/2022 8:16 pm
Lichtjaeger
(@lichtjaeger)
You can use official calibration files even now, but you have to use the beta firmware.
Posted by: @mikeh-2
Posted : 15/04/2022 7:04 am
MikeH
(@mikeh)
Thanks for the info.
Posted : 15/04/2022 7:08 pm
CR3D
 CR3D
(@cr3d)
Anyone have an issue with new boost board and firmware 1.6.6 ?
Also tried beta 1.7, it's worst...
This post was modified 3 years ago by CR3D
Posted : 29/04/2022 3:23 pm
