[Résolu] Resin stuck to the tnak bottom
karlos.v
(@karlos-v)
Hello to all
After my second print, a big piece of resin remained stuck to the tank bottom.  Is there any way to remove this resin or should I replace the bottom film? Also on  the printing platform got stuck all the tiny bases of the supports.
Does it happened to anyone else?
Thanks for your help 🙂
Publié : 28/09/2019 6:25 am
karlos.v
(@karlos-v)
RE: Resin stuck to the tnak bottom
A few days ago, before start printing, I read in the manual you can press with your fingernails on the other side of the FEP film to detach the solidified resin ... I did it, but it is too stuck to the film.
Publié : 28/09/2019 2:11 pm
I use a microfibre cloth and use my fingers (NOT FINGER NAILS) press through it, and the FEP Film, starting at the film outside the stuck piece, and wipe into the middle of the stuck piece, from all edges.   and this has always popped the waste material off the FEP Film, for me!
Publié : 28/09/2019 2:28 pm
3 personnes ont aimé
karlos.v
(@karlos-v)
RE: Resin stuck to the tank bottom
Hi Joan! thank you very much, it worked!
Publié : 30/09/2019 7:04 am
