No space left on device
patrick.v2
(@patrick-v2)
This is the message I get when sending an .SL1 file to the SL1 printer via PrusaSLicer
so what now ?
Didn't see an option in the printer menu to manage internal storage and didn't find a way to browse the internal memory from the PC
Opublikowany : 08/10/2019 9:53 am
patrick.v2
(@patrick-v2)
RE: No space left on device [ solved , well it's a workaround]
Hi all,
got an answer from support that I share with you:
It looks like you're running low on internal memory.
You can delete the existing files to free up some internal memory.
Just go to Main Menu -> Print, then slide the file to the left - it will reveal a waste bin icon. Tap it and the file will be deleted.
this solves the problem indeed but still we have no remote access to manage this storage. I would advice to also export the sliced models on the workstation in order to keep a copy of what is being sent to the printer.
kind regards
patrick
Opublikowany : 10/10/2019 7:36 am
