Calibration/first print issue.
Jerome Girard
(@jerome-girard)
When I calibrate the printer, at the resin tank and display alignment steps (3 and 4 in the handbook), I have a slightly height difference between the two sides, right and left, approximately 0.2mm. So I could not align the display properly.
Is it normal?
My first print failed, (first layer won't adhere to platform), is there any relation?
Thanks in advance
Opublikowany : 08/12/2022 9:25 am
UnumDesignum
(@unumdesignum)
RE: Calibration/first print issue.
Bonjour Jérôme,
Make sure all screws are strongly bolted, in particular those under the tank.
Opublikowany : 10/12/2022 11:04 am
