Layers separating as the height increases
I'm printing a model using eSun ABS+ filament, and find that the layers keep separating as the model increases in height. It is sticking well to the build plate.
I don't find any configuration for ABS+ filament so I'm using the standard ABS config, although maybe this doesn't have a bearing on my problem.
Can anyone please advise what the issue might be? See the attached file to view the print.
Opublikowany : 01/05/2025 5:15 pm
