Improper Slice
Webscalp
(@webscalp)
Improper Slice
Hello,
As you will be able to see on the screenshots bellow, the spur gear I am trying to print on my MK3.5 (the problem is the exactely the same with MK4) cannot be printed properly.
Teeth are missing on the upper part of the gear (why ???), and are even not the same size in the lower part of the gear.
I am all the more upset that I canot detect the thin walls (the box is grey and cannot be checked)
That's the reason why I am calling for your help.
Thanks in advance
Respondido : 19/07/2024 3:39 pm
RE: Improper Slice
Can you Save that Prusa slicer session, including the gear as a project file, then Zip Compress the file, and attach it here with your next post?  please
and we may be able to help you
Joan
Respondido : 19/07/2024 4:15 pm
Webscalp
(@webscalp)
RE: Improper Slice
Here you are !
Thanks in advance and have a good week-end !
Respondido : 19/07/2024 4:39 pm
RE: Improper Slice
Hi Webscalp,
I think you have hound one of the treasures of the forum
If you don't give it the right file type, everything looks OK, but the forum doesn't include the file!
Respondido : 19/07/2024 6:59 pm
Webscalp
(@webscalp)
Hello , Joan,
It is ok, now ? (I was persuaded to have joined the file, but it seems it wasn't...).
After multiple tries, it seems I cannot joine a file (why ?...) So, I give you a download link
https://www.dropbox.com/scl/fi/hbaf4707v7fgnt2ipzvyr/Engrenage-blanc-petit-v2.zip?rlkey=8qlrw1n110yi48k81k4jhnza0&dl=0
Esta publicación ha sido modificada el hace 2 years 3 veces por Webscalp
Respondido : 22/07/2024 8:00 am
