Why does the MK3.5 not support Input Shaper
ChrisG
(@chrisg)
Mitglied
I looked a few youtube movies from Chris's Basement about Input Shaper. I am hooked. But the forum does not have a Input Shaper area for MK3.5. And I tried to change the X-parameter value via an G-code file with the M593 code but the value is did'nt change. I could check this while printing nut the X and Y values stay the same. In the end of every G-code file the X and Y are set to zero via the M593 code. When I look in the menu Settings/Input Shaper the X and Y has still the value 50 and 40. If Input Shaper would work it would be 0, 0.
Am I correct en will this added in een newer firmware release?
Veröffentlicht : 09/06/2024 5:33 pm
duebelpapst
(@duebelpapst)
RE: Why does the MK3.5 not support Input Shaper
Hello,
I have the same problem.
The values for Input Shaper cannot be changed on the printer, and M593 X T2 F48 at the end of the start Gcode does not change anything either
Regards,
Stefan
Posted by: @chrisg
Veröffentlicht : 16/06/2024 4:54 pm
