Revo now working with Firmware 5.2.2
After flashing the new firmware I ran the heater test and it failed. After a few seconds the option appeared to select a Revo hotend. After cooling down and rerunning the test, both hotend and bed test passed. I later discovered that if you select Settings and then Hardware there is a new option Hotend Type. Here you can select Stock, Sock or E3D Revo.
Many thanks to the Prusa software team.
Opublikowany : 20/03/2024 6:33 pm
1 ludzie polubili
