[Risolto] PrusaLink update Problem
Floe
 Floe
(@floe-2)
I'm running into a problem with updating my prusaLink on a RPi ZeroW on my MK3S.
I'm already running the setup with the internal Rpi for a couple of years, without any issues. I just decided to update to the latest PrusaLink 0.8.1 version.
My printer is updated to the most recent 3.13.3 FW. Rpi Port on the Machine is on.
After I flash everything the machine is booting the rpi and connects to PrusaLink, I can access via .local and IP.
But when I open the page I constantly get the error:
"Firmware is not up-to-date, please update it! You can download the latest stable firmware at Drivers, Firmware and Manuals download page. Follow the instructions in this guide. After upgrading, run this wizard again. "
I tried reflashing both the printer and Raspberry and double checked that I'm using the lastest firmware version. Both avrdude and the PiImager give back successful flash confirmations.
Behaviour is unfortunately exactly the same.
I would apprechiate some help,
Thanks in advance,
Flo
Postato : 03/07/2024 8:40 am
Duiglen
(@duiglen)
Utenti
RE: PrusaLink update Problem
I think PrusaLink 0.8.1 requires firmware 3.14.0 or newer, double check your current version.
Postato : 03/07/2024 7:59 pm
Floe
 Floe
(@floe-2)
Thanks,
You were right,
I was just with a bad timing, updating the prusalink a couple of days before the new firmware for MK3S came out.
Marked the problem as solved
Best,
florian
Postato : 09/07/2024 4:54 pm
