Parts fan, disable for color change and pause
Hello! Some time ago I've bought Prusa MK3s+ and while using Filament change or pause feature in PrusaSlicer 2.7.4 it caused the printer to park and disable parts fan (which for me is great).
Lately I've upgraded the printer to MK3.5 (FW 6.0.1) and noticed that when using filament change or pause feature, part cooling fan is continuously spinning, which causes nearby corners of prints to lift up from the bed (happened at least 3 times, so I pretty sure it's this fan's fault)
Is there a way to add some custom g-code to pause/filament change command so that it stops the fan until print continues?
Postato : 06/06/2024 7:14 am
