Mk3S+ 3.13.x flash failure
Out2sea71
(@out2sea71)
after flashing printer with newest 3.13.1 firmware the screen refreshed with the announcement of flash complete/successful and asked whether a heat calibration can be launched and that it would need about 12 minutes.  I start the test and before the extruder reaches 200 an alarm starts and will not stop until I push the reset.  I reload the firmware again and no change.  I tried to skip the calibration and print a simple test but I would get the same results when the extruder approaches 200.  There is a new menu item "TM RESET" but this requires 3x choosing before the alarm stops.  I have reloaded 3.11.x in the meantime because it is the last one that was fully successful.  I am running a pre 2019 LDO unit.  Thank you in advance for any assistance you may lend.
Napsal : 17/10/2023 12:18 pm
Crab
 Crab
(@crab)
RE: Mk3S+ 3.13.x flash failure
My MK3S+ will die on 3.11!
Napsal : 17/10/2023 4:23 pm
Out2sea71
(@out2sea71)
This is my original machine and it has 1182 days 9 hours and 51666meters on the tacho.
Napsal : 17/10/2023 4:59 pm
