Mk3.5 started printing with very poor adhesion
mpeill
(@mpeill)
Mk3.5 has always printed great, but just started to give very poor results with bad adhesion. I've attached a photo of the pre-print filament as the head first comes down onto the build plate to start the print. This has normally been a smooth strip before then moving onto the model itself, but is now ridged. I tried to also attach a photo of the model but could only attach one file. Any ideas what is causing this. Could it be a nozzle issue. The nozzle and bed both reach the correct stable temperature before starting the print run.
Any help appreciated.
Opublikowany : 08/08/2025 8:10 pm
